Ive got a Maxim MAX630 CMOS DC-DC regulator, wired up deadbug style, that is putting out a little less voltage then I'm putting in it.
Here's the Full
Data sheet
I can't get this to work right for the life of me. I'm putting between 6.6 - 8.2v input, looking for anywhere between 12-15v out (150ma peak).
I'm using -
D1 : 1n5819 schottky
L1: low esr 19r474c 470uh power inductor (1.1A rating)
C1 : 470uf electrolytic in parallel with a 22uf tantalum
Cx: 47pf ceramic
R1: 91k
R2: 10k
Cc: 10nf mlcc
Don't have R3,R4, pin 1,or pin 8 connected
Ive spent the better part of 3 hrs looking over this, and cant find any visible reason it should be working like i want.
i thought it was maybe the esr on the 470uf, added the 22 in parallel. then CC. Then considered it could be a dirty power supply. dug another one out. Then used batteries.
I did have it powered on with R1 & R2 reversed - could i have toasted the comparator op-amp?
I'm under the opinion that the chip is bad, but the thing is like 8 bucks (and i don't have another handy).
Does anyone see something i missed?
