Author Topic: Negative voltage on BLDC Hall Effect output  (Read 1511 times)
Offline Tin Duc VoTopic starter
« on: June 17, 2016, 08:54:29 pm »
Hey everyone,
I was wondering if anyone knew why the Hall Effect sensor output of a three phase BLDC would go negative? The motor I am using has a Hall Effect module with 3 signals + power and ground. I hooked it up like in the picture below. For some reason, all of the signals spike to some negative voltage when they're not supposed to transition and then decay back to zero. I can't have this because it would destroy the other components. If anyone could help me with figuring out why this output is going negative, that would be lovely. Thank you :).
Offline uncle_bob
Re: Negative voltage on BLDC Hall Effect output
« Reply #1 on: June 18, 2016, 06:52:48 pm »
Hi
Most likely reason - because the sensor is grounded to the motor frame and that ground is not the same as the ground in your measuring setup.
Bob
« Reply #2 on: June 20, 2016, 01:09:39 pm »
Thank you, Uncle Bob. I actually did not ground the case of the sensor to the circuit ground because I did not think that would be so crucial, but I will try that now. Honestly, I do not understand why that would cause the circuit to do this, but if it works, I will report back. If it does not work, I will also report back ... but with a nice picture :).
