Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Wiring 6063 LEDS
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Wiring 6063 LEDS (Read 3309 times)
CheetoPuff
Newbie
Wiring 6063 LEDS
on:
January 10, 2015, 06:31:41 pm »
I wired a bunch of 6063 LEDs using enameled magnet wire and I'm wondering what I can dip the LED into to seal the end? I don't like leaving the end exposed like that. Pic below
Logged
devanno
Regular Contributor
Country:
Old newbie
Re: Wiring 6063 LEDS
Reply #1 on:
January 10, 2015, 06:59:19 pm »
I think that kind of depends on where that LED is destined. I have used some "Super Corona Dope" on the back of some of mine that I use in modeling so the leads don't short.
http://www.mgchemicals.com/products/protective-coatings/insulating/super-corona-dope-4226/
Logged
Free Electrons - Just one, please.
CheetoPuff
Newbie
Reply #2 on:
January 10, 2015, 07:06:56 pm »
Is that stuff clear? My first thought was to just use medium CA glue (super glue), but I'm not sure if it is non-conductive. Basically I need something that is clear (so the light can shine through) and non-conductive. If anybody else has any ideas please let me know.
Logged
Yago
Frequent Contributor
Country:
Reply #3 on:
January 10, 2015, 07:15:05 pm »
This might be the place to find something:
https://www.norlandprod.com/adhesiveindex2.html
Logged
CheetoPuff
Newbie
Reply #4 on:
January 10, 2015, 07:17:34 pm »
I was reading about the Super Corona coating and it is clear. I will probably use this. Thanks
Logged
devanno
Regular Contributor
Country:
Old newbie
Reply #5 on:
January 11, 2015, 07:35:46 am »
Hope it works out for you. The stuff is "dope" so have ventilation.. and it can be kind of thick. I believe there is a thinner for it, but you also don't want it running all over the place.
I often use disposable "micro brushes" (hobbyist tiny paint brushes) when I'm working with tiny amounts of product like this. Superglue (AC / CAC / many names) is not conductive when dry, but it is brittle... it may just pop off if the leads get flexed.
Logged
SeanB
Super Contributor
Country:
Reply #6 on:
January 11, 2015, 08:40:01 am »
I normally keep a small tin of water clear polyurethane varnish around, just for this. Dip in the varnish and leave to dry, wicking the excess off with a kitchen paper towel to leave a thin film, then hang to air dry. Leaves a thin film of clear that will flex slightly with movement.
Logged
devanno
Regular Contributor
Country:
Old newbie
Reply #7 on:
January 11, 2015, 09:54:46 pm »
Good approach, SeanB. I'll give that a try. Usually, I'm mounting the silly wired SMD LEDs in something metal, and don't want to risk any kind of a short, hence the dope. Maybe I'm the dope. :-)
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Wiring 6063 LEDS
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
