Author Topic: Modern replacement for LM628/629? Servo motor control  (Read 2831 times)
Offline Photon939Topic starter
« on: February 14, 2018, 09:21:24 pm »
I've been looking into the fact that small DC brushmotor servo drivers are not an easy item to find at reasonable prices.  The application I have in mind is CNC for stuff like 3d printers and laser cutters.  Is there a modern equivalent for the LM629 precision motion controller?
https://www.mouser.com/ProductDetail/Texas-Instruments/LM629M-6-NOPB?qs=sGAEpiMZZMvu8NZDyZ4K0Qh6JMP%252bT6Sa
I'm also open to the possibility of doing brushless motors as well.
I'm looking for drivers that integrate with incremental shaft encoders.
Thanks in advance for any suggestions.
Offline Kjelt
Re: Modern replacement for LM628/629? Servo motor control
« Reply #1 on: February 17, 2018, 10:45:14 pm »
I was wondering the same thing, my guess is that some things have changed since late 90s when the lm628/629 came out:
- cheap steppermotors replaced the brushed dc motors, also then no real need for encoders unless you have heavy usage such as cnc milling where you might loose steps.
- microcontrollers have become so cheap and powerfull that semiconductor manufacturers don't see a market anymore. A stm8 for $2 should be able to handle this esp. Dedicated to a single motor and encoder as the lm 62x's do
Offline danadak
« Reply #2 on: February 19, 2018, 02:11:12 am »
PSOC Motor Control -
http://www.cypress.com/applications/automotive-solutions/motor-control
Onboard DAC, ARM Core, A/D, Digital Filter + a whole lot more....
Regards, Dana.
Offline Kjelt
« Reply #3 on: February 19, 2018, 06:05:06 pm »
Regards, Dana.
I don't see the feedback loop (quadrature decoder) which is what makes a motor a servo.
Offline perdrix
« Reply #4 on: February 19, 2018, 06:49:44 pm »
You may wish to take a look at Microchip AN532 which describes a servo motor control system using a PIC17C42 and a PLD.
This was used very successfully as the basis of the dual servo motor controller in the Losmandy Gemini-1 telescope control system.
The 17C42 is now somewhat dated, but the concepts and the code are still valid and it could readily be ported to a newer PIC (beware clock rate differences).
HtH
David Partridge
The following users thanked this post: Photon939
Offline danadak
« Reply #5 on: February 20, 2018, 12:47:33 pm »
There is a posted project here, if you have loaded Creator on you
PC.
http://www.cypress.com/forum/psoc-3-known-problems-and-solutions/servo-motor-interface-psoc-3
Here is a BLE application -
https://www.embedded.com/print/4458293
Regards, Dana.
« Reply #6 on: February 20, 2018, 09:11:18 pm »
PC.
Regards, Dana.
These projects are not applicable for my project, these are for hobby RC servos which do not have position feedback.
« Reply #7 on: February 20, 2018, 09:14:51 pm »
HtH
David Partridge
Thanks this is the type of application I am looking for. I do have a PSOC from Cypress I got at world makerfaire that might allow me to do all of these digital functions within one chip. I hope I can get the hang of it after being an Arduino scrub for ages.
