Author Topic: Modify PIR sensor motion detector circuit  (Read 1659 times)
Offline fixit7Topic starter
Offline soldar
Re: Modify PIR sensor motion detector circuit
« Reply #1 on: May 15, 2019, 09:41:47 pm »
Yes but wouldn't it be simpler to just buy one with a buzzer? Like the ones they have in stores when a customer walks in or out. They are very cheap.
« Reply #2 on: May 15, 2019, 11:49:57 pm »
I could but I would not learn as much.
And I want to be able to modify the circuit.
Offline soldar
« Reply #3 on: May 16, 2019, 12:01:59 am »
You can try this.
The following users thanked this post: fixit7
Offline floobydust
« Reply #4 on: May 16, 2019, 12:20:36 am »
The HC-SR501 IR motion sensor uses the BISS0001 motion sensor IC. It has a weak output. You need to add a NPN transistor to drive piezo beeper or relay.
For more information, look for BISS0001 circuits.
« Reply #5 on: May 16, 2019, 12:54:10 am »
« Last Edit: May 16, 2019, 12:55:43 am by fixit7 »
Offline techman-001
  • Electronics technician for the last 50 years
    • Mecrisp Stellaris Unofficial UserDoc
« Reply #6 on: May 16, 2019, 01:12:28 am »
Can this be modified to use a piezo buzzer?
https://circuitdigest.com/electronic-circuits/pir-sensor-based-motion-detector-sensor-circuit
Thanks.
Sure easy peasy , learn about transistors and or fets and use one in place of the led, to drive a buzzer.
« Reply #7 on: May 16, 2019, 02:05:53 pm »
Thanks.
Thanks.
I am reading Practical Electronics for Inventors.
I could use some more details on your recommendation.
I am a relative beginner.
