Is the clock ticking too fast, or to slow?
When we were teenagers we used to tune electronic wrist watches by adding a very small capacitor in parallel with the 32768Hz resonator.
Since SMD parts were not yet a thing, and there was virtually no room inside a wrist-watch, the tuning capacitor was a DIY hand made:
- on a piece of 0.5-1mm thick CuEm wire of about 1-2cm long, wind 0.1-0.2mm diameter CuEm wire on the entire length of the thick piece of wire, one layer of thin wire, no interleave space
- cover all with nail lacquer and keep all tight until the lacquer solidifies
- at one side of the thick wire, remove the Em isolation for both the thick and the thin wires
- solder that in parallel with the 32768Hz resonator
Frequency adjustment is made by un-winding and cutting away a few turns from the thin wire each time, then let it run for 1-2 days to compare the time, then uncoil from the loose end a couple more turns and let it run a few more days again, and so on until you get a reasonable small time skew. Leave uncut the empty end of the thick wire that remains after consecutive un-winding of the thin wire, always cut only the un-winded remaining of the thin wire.
