By ear I can clearly hear the difference between using the original design with the 3.3V LDO (which is dead silent) and using the charge pump (which has a bit of a white noise).
And just to be clear I do not have a PCB with the charge pump (yet), so for now the charge pump IC is simply soldered on a small adapter board and then attached to the original PCB (i.e. the one with the 3.3V LDO) using short cables.
EDIT: Nevermind, this noise is clearly unrelated to the charge pump as the exact same can be seen on both version (the quiet 3.3V LDO version and the charge pump version). I guess this could come from the USB power supply (external) which for sure has a switcher inside.
See next post for audio range noise floor measurements.
I tried to see on the oscilloscope but it's just general noise of about 50mVpp at high frequencies, the 1.2MHz switching freq is not at all predominant.
This was measured. It is very strange, the noise I can see is basically:
* The noise floor around 10mVpp
* A "clump" of 60mVpp noise at 10-11Mhz, of about 500ns, coming every 21us (=47kHz)
I've attached a few of the noise, the associated FFT, and a zoomed view of the "clumps".
