Author Topic: DC Grounding Circuit Undrestanding  (Read 637 times)
Offline mostatabTopic starter
  • Country: ir
« on: October 13, 2021, 09:06:49 pm »
I'm inspecting an industrial PCB which use 8 VAC voltage as input. Then a diode bridge is used in order to rectify this voltage. I've found they have used the attached circuit for the DC part of the power supply. However, I couldn't understand why they use such circuit.
" alt="" class="bbc_img" />
Could you please explain why these circuit is used?
Thanks
Offline TimFox
Re: DC Grounding Circuit Undrestanding
« Reply #1 on: October 13, 2021, 09:14:52 pm »
Are you sure that the three symbols for DC power, Ground, and Earth are correctly drawn?  The circuit that you show (by itself) makes no sense.
  • Country: ir
« Reply #2 on: October 13, 2021, 09:19:44 pm »
Yes, my apology. the used symbols are not correct. the GND net is connected to negative pad of the bridge, and the Earth is connected to the chassis.
« Last Edit: October 13, 2021, 09:24:57 pm by mostatab »
Offline TimFox
« Reply #3 on: October 13, 2021, 09:31:11 pm »
Well, C19 and C20 bypass the DC output nodes of the bridge to Earth/Chassis.  The diode might prevent reverse voltage under fault conditions.  C21 might be a filter capacitor (is the negative terminal of the bridge grounded elsewhere?), and the resistor a bleeder on C21.
« Last Edit: October 13, 2021, 09:33:26 pm by TimFox »
Offline radiolistener
  • Country: ua
« Reply #4 on: October 13, 2021, 10:08:36 pm »
there is no bridge on your schematic
