I dont know exactly, so I'm down a few points there. But I know that low resistances heat up more than high resistances with the same wattage, and not all your power is going down the whole thing, Alot of the time I end up with 1 fried resistor and the rest are ok.
But I think I'm missing a piece of knowledge here to answer your question properly.
Thank you, now we’re getting somewhere. Remember, nobody here is trying to embarrass you or anything. But you did need to stop acting as if you understand everything, and coming in making grand claims about things you don’t actually understand.
Every single one of us here was a total beginner at some point, and gained knowledge over time. You will too and people here will help!
Your observations about resistors are partly correct. The wattage of a resistor is simply how much heat it can tolerate before it burns up. That’s independent of the value as such.
You sorta correct that, with voltage (not power!) held equal, a resistor of lower resistance will heat up more than one with a higher resistance. This is Ohm’s Law at work: as the voltage “pushes” current through the resistor, the lower resistance allows more current to flow, but also means a larger voltage drop. The larger current, according to the formula I gave earlier (P
loss=I
2R)*, means more heat.
A higher value (resistance) resistor will heat up just as much, it just takes a higher voltage to do it. For example, 1A through a 10 ohm resistor, or 0.1A through a 1000 ohm resistor, both dissipate 10W. Within a product line, both of those resistors would be the same size and appearance, though their internal construction would differ. (And the voltages would differ: the voltage across the 10 ohm resistor would be 10V, while it’d be 100V across the 1000 ohm resistor.)
In a voltage divider, the voltage gets divided up proportionally among the resistors, as you know. The current, however, may not be the same across the branches of the divider. Since current is what causes the heating, the differing amounts of current through different branches is how you’ve ended up with some resistors fried and others fine.
That’s a great observation. The key now is to understand why and how it happens.
*this is known as Ohm’s power law. P
loss=I
2R is basically shorthand for P
loss=V*I, referring not to the supply voltage, but to the voltage drop across the resistor. But to calculate the voltage drop is I*R, so we just substitute that into the formula, giving I*R*I, or I
2R.
