Mechatrommer, consider editing the title to something containing the phrase “melting point” since it’s clearly already caused confusion to some as to whether you mean what reflow temperature you use.
The melting points are the same for paste and wire solder, of course; the alloy alone determines this. So standard 63/37 leaded is 183C, 60/40 leaded 183-188C (since it doesn’t melt at a single temperature, since it’s not eutectic).
You should also add 227C to the poll, since that is the temperature of most of the newer lead-free alloys.
