Also note that different maximum ratings, such as VDS, ID, and power dissipation are quoted by the manufacturer, but that does not mean that you can run the device at its maximum voltage and maximum current, simultaneously, if the resulting power dissipation exceeds the temperature-derated power rating with your heat sink (or none).
For switching MOSFETs, one typically runs near maximum current at very low voltage, and maximum voltage at very low current, and then looks at the SOA to see what happens during the switching transition from ON to OFF, respectively.
