Yes, KiCad is (or at least can be) quite keyboard-driven. I like it for the same reason.
I'm trying KiCad and it seems like I can learn to use it, But I have one major problem - everything is mirrored, if I move my mouse to the left the sheet moves to the right, also every compoent letter is mirroed like this:
Also I have to click end tool on everything and that is just annoying, is there anyway to disable it so it will be like in ltspice where you just right click when you finished?
Also when I click the home button the sheet just becomes black and I have to zoom in to fix this (bug)
Also everything I click on F3 which I set to "Begin Wire" it just draw random wire and not just switch to the tool.. (other bug).
I think I have some technical problems with kicad, time to format this damn crappy windows 10.
too many annoying things..
