Hello folks!
I'm testing my understanding of MOSFETS. I picked one that I had, BS170 enhancement type MOSFET.
I designed an experiment where I'm trying to determine what V
GS I need to I
D=150mA @ 5V. I hooked up a pot to an arduino, where based on the voltage @ the pot, I change the duty cycle of an analog pin. That pin is hooked up to the gate of the MOSFET via a 5K resistor. (Please see the simulation).
On the simluation, I can read that I need about 3.7V on the gate to get 150mA current to flow on the drain. On the datasheet, I read something similar.
In measurement, I saw something completely different. I only took 4 measurements but it should give you an idea why I'm confused. (I measured the current with a multimeter and V
GS with an OScope - V
GS is the mean of multiple PWM cycles where PP is 0-VCC)
My first surprise is that the MOSFET starts conducting way below 2V, which I saw in the datasheet. Why could that be?
