Is R3 necessary?
You're right, not needed.
Make sure to use a resistor capable of handling 1W for R4.
Thanks. Larger R4 value would be better.
mosfet destruction.
Well, maximum current will be 3amps, i think should be ok.
Is there any reason the switch is in a 5V circuit ? why could it not switch the mosfet gate directly ? but perhaps you are intending to drive it from an mpu.
Your circuit shows both 24V & 0-35V, perhaps that is a nominal and a range ?
Finally is your load inductive ? if it is you will need a catch diode to protect the mosfet from avalanche.
Yes, i will drive the npn via 555 timer. Also that will allow turning on the mosfet when low side is all the way up to the ground?
The +24 is simply because Eagle cad had that label on component
Bit misleading, sorry.
Yeah, catch diode is intended, just not shown here.
Thanks!
