Electronics => Beginners => Topic started by: twam on December 29, 2019, 03:57:22 pm
Title: MOSFET for higher voltages (30-40 V)
Post by: twam on December 29, 2019, 03:57:22 pm
Hi everybody,
For switching my flipdots I finally decided to use a capacitive-discharge approach. It currently works fine when using with the attached schematic and a voltage of 24 V. For switching the voltages I use DMG6602-SVT (https://www.diodes.com/assets/Datasheets/products_inactive_data/DMG6602SVT.pdf).
[attach=1]
Now I want to increase the supply voltage to something between 30 V and 40 V. According to the data sheet the DMG6602-SVT has a breakdown voltage of 30 V, so I'm looking for alternatives. I was thinking of something like the DMP4025LSD (https://www.diodes.com/assets/Datasheets/DMP4025LSD.pdf) for the P-Channel and BSS123 (https://www.onsemi.com/pub/Collateral/BSS123-D.PDF) for the N-Channel MOSFET. DMP4025LSD has a breakdown voltage of 40 V which should be fine, however the maximum gate-source voltage is +- 20 V. Also almost all other P-Channel I found with higher breakdown voltage have a similar maximum gate-source voltage. How can I use them in a similar setup?
Title: Re: MOSFET for higher voltages (30-40 V)
Post by: Yansi on December 29, 2019, 04:34:42 pm
How is that circuit supposed to work? You are not only using unsafe supply voltage (V is littel too much for a 30V fet), not mentioning the Vgs maximum voltage rating, that you are already exceeding.
What is this circuit supposed to do?
Post by: magic on December 29, 2019, 06:09:35 pm
Big distributors like mouser or digikey have comprehensive databases and parametric search which will allows you to find thousands of FETs with just about any parameter you may desire, as long as such parts exist.
That being said, MOSFET gates are quite delicate so 30V rating is somewhat uncommon and more than that is very rare. Add 10k resistors at the drains of the N-FETs and then the P-FETs will see only half the supply voltage at their gates.
Post by: twam on December 29, 2019, 06:55:53 pm
Charge and Pulse are controlled by the µC to charge and discharge the capacitor. The output on the right is VCC for an UDN2981/TBD62783 transistor array which is then connected to the flipdots.
Post by: Yansi on December 29, 2019, 07:05:00 pm
I still don't understand the purpose of this circuit.  What is this circuit good for, in a flipdot driver?
Post by: Wimberleytech on December 29, 2019, 07:36:46 pm
I have no clue about flipdots.  That being said, why not just use a voltage divider as shown here (first stage only).
Post by: twam on December 29, 2019, 07:41:13 pm
The capacitor is charged and then decoupled from supply. Then it is decharged via the flip dot which is connected to GND. The flip dot is basically just a coil.
Post by: Yansi on December 29, 2019, 08:26:18 pm
Professionally made flipdot drivers do not contain any such circuits.
I am still failing to understand, what your intention here is.  Probably, sort of "charge metereing device". But what for? Unlikely to work this way anyway. You will crap the charging mosfet out on first turn on.
Post by: Alex Eisenhut on December 29, 2019, 08:28:00 pm
But the current pulse from charging the capacitor directly is ... probably even bigger than the load you're trying to isolate?
Post by: twam on December 29, 2019, 09:22:23 pm
This method was suggested by in this post (https://www.eevblog.com/forum/beginners/switching-flip-dots-current-limited/msg1389740/#msg1389740) and also this project (http://www.vagrearg.org/content/flipdemo) uses the same approach.
The displayed schematics works fine so far with several days of runtime switching every 150 µs.
Post by: Yansi on December 29, 2019, 09:48:40 pm
With the exception, that the charge power supply is a constant current source there.
Nowhere one can see it in your drawings.
Post by: Zero999 on December 29, 2019, 11:19:45 pm
I'd replace the MOSFET with a BJT and add a suitable emitter resistor to give the required gate voltage.
(https://www.eevblog.com/forum/index.php?action=dlattach;topic=215026.0;attach=857684;image)
Post by: jonroger on December 30, 2019, 01:04:12 am
+1 on adding a resistors to form a voltage divider.    Without it, Vgs on QxB will exceed maximums.
