Author Topic: MOSFET Fried, how can i tell why?  (Read 9474 times)
Offline Chet T16Topic starter
  • Country: ie
    • Retro-Renault
« on: May 29, 2011, 08:04:12 pm »
As i have mentioned elsewhere i was making a fuel injector pulser based around an IRFZ34N and today i gave it a full test and it fried, d'oh.
The connected load was 4, 3.5 ohm injectors in parallel, powered from a car battery with 13V.
From the mosfet datasheet it says that the Rds is 0.04ohms which should mean only a tiny amount of power being dissipated (around 8W) so i hadn't even considered a heatsink or anything
It worked for a while, 30-45 seconds than let out the magic smoke without any pop bang or fizz and the mosfet is now short circuited.
I was using a suitable flyback diode across the load
Everything else in the circuit works fine still
Any ideas where i've gone wrong?
(Schematic coming as soon as i figure out how to make one)
Chet
Chet
Paid Electron Wrestler
Offline Rufus
Re: MOSFET Fried, how can i tell why?
« Reply #1 on: May 29, 2011, 08:19:32 pm »
8W is not tiny. A junction to ambient thermal resistance value is given in the datasheet you linked.
62 C/W meaning that with no heatsink the device would have to run at almost 500C to dissipate 8W.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: May 29, 2011, 08:23:11 pm »
yes you need a heatsink. Also if you are turning the mosfet on and off quickly this will make more heat because the mosfet will not always have a resistance of 0.04 ohms as it will take some time to turn off during which the resistance is higher and so more heat is made.
Online Zero999
  • 0999
« Reply #3 on: May 29, 2011, 08:25:41 pm »
I make it closer to 9W, 8.83W to be precise.
Yes, that's to be expected, I don't see why you're surprised, you exceeded the maximum operating junction temperature of 175oC by around 400oC. I suggest reading the datasheet again, doing the temperature rise calculations and using a suitable heat sink.
What's the gate source voltage?
Offline Neilm
« Reply #4 on: May 29, 2011, 10:32:23 pm »
Switching losses are pretty hard to calculate correctly. One explanation I found to calculate this was in a TI datasheet http://focus.ti.com/lit/ds/symlink/bq24600.pdf If you go down to page 23 you will find some data on how to calcultate switching losses. This is tailored for the application in the datasheet but you should be able to use it to approximate the losses you will be experiencing in your application. I have used these formula to calculate how hot MOSFETs were going to get with a reasonable degree of accuracy.
Yours
Neil
« Last Edit: May 29, 2011, 10:34:57 pm by Neilm »
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Simon
  • Global Moderator
« Reply #5 on: May 30, 2011, 07:52:42 am »
well I just tend to "judge by eye" although I've never done any complex stuff. I remember building a 555 based PWM speed controller for a car blower (8A motor) and added an optional capacitor in parallel with the timing capacitor to reduce the frequency. The difference in temperature of the mosfet was noticeable even though on a heatsink being cooled by the fan itself. I learnt a valuable lesson early on and thankfully have never burnt a mosfet out
  • Country: ie
    • Retro-Renault
« Reply #6 on: May 30, 2011, 12:13:43 pm »
Clearly i f'd up here. I think this may be (in part) because i was originally intending to drive only one injector so the load was much less and the specs for that mosfet might have been confused with the curent one along the way. Vgs is 5v which i believe would have lead to a higher value for Rds
I came across this (available from farnell) which looks like it would work much better with a small heatsink. The ones i fried came from ebay in some questionable packaging so i'm not 100% certain they are what they say they are
Chet
Offline jahonen
« Reply #7 on: May 30, 2011, 01:50:08 pm »
I think this is also a big problem. Consider using a logic-level MOSFET, which achieves specified Rds(on) with 5 volts, or, gate driver circuit which raises the gate-source voltage to appropriate levels.
Regards,
Janne
Offline Simon
  • Global Moderator
« Reply #8 on: May 30, 2011, 02:16:46 pm »
yes logic level mosfet just to be sure. I got away with plenty with IRF540 devices run from a 5V pic but for any real power I'd use the equivalent logic level mosfet by the similar name of IRL540
From a personal point of view, the packaging don't always mean much, I've sold mosfets I bought from major uk suppliers and mosfets bought from china in ziplock bags and it don't mean they were bad and i've had no complaints, I think you just abused the mosfets you bought.
Put a heat sink on and try again. What you need to remember is that with a heat sink the heat will gradually dissipate away. With no heatsink it builds up fast, even that little extra dissipation area helps alot - a lot like a car radiator (I work for a radiator company) the in and out temps are only a few degrees apart, but taking those few degrees off at a time is enough to maintain a stable temperature
« Last Edit: May 30, 2011, 02:20:46 pm by Simon »
  • Country: ie
    • Retro-Renault
« Reply #9 on: May 30, 2011, 04:27:33 pm »
Oh yeah, they were certainly abused and the failure was totally my fault!
I'll retry with a heatsink and see how it goes. I haven't any new ones but i seen a couple on an old board somewhere
Chet
Online Zero999
  • 0999
« Reply #10 on: May 30, 2011, 06:05:30 pm »
I had a feeling you were doing that but no one knew because you didn't post a schematic.
The IRL540 springs to mind but there are probably better, more cost effective MOSFETs available. Going from the worst case, you should use a heat sink with a thermal resistance of 4oC/W or less.
http://www.vishay.com/docs/91300/91300.pdf
« Last Edit: May 31, 2011, 01:52:09 pm by Hero999 »
Offline Simon
  • Global Moderator
« Reply #11 on: May 30, 2011, 06:36:14 pm »
so does Rds get lower for Vgs that is higher than 4 or 5V ? I hope so because the datasheet for MY irl540 states 44mR so i assumewith something like 10V
Online Zero999
  • 0999
« Reply #12 on: May 30, 2011, 06:43:08 pm »
What do you think?
Are you sure it isn't the IRF540? It's a similar MOSFET but with a lower on resistance and is not logic level so has a higher threshold voltage.
http://www.irf.com/product-info/datasheets/data/irf540n.pdf
Offline Simon
  • Global Moderator
« Reply #13 on: May 30, 2011, 06:54:31 pm »
not sure, but then I have seen a few variants of the IR*540 family, adding an N to the end often produces a part that can handle more amps, it could be I'm thinking of the resistance spec for that variant although any of the two vary slightly from one manufacturer to the next
Online Zero999
  • 0999
« Reply #14 on: May 30, 2011, 10:00:37 pm »
Yes, the IRF540N seems to be a newer, updated version - manufacturers often do that.
