I've got another question, for the same circuit (i.e. sine wave input on both AD633 inputs, but this time at 1kHz).
When I calculate the scale factor from the input and output signals of the AD633 (which should be 1/(10V)), I get a much lower value when the input is only positive than when the input is only negative. (Scale factor when input is positive: 9.8, scale factor when input is negative: 9.9)
Is there a possible reason that the AD633 behaves differently for positive or negative inputs? (Note: the Ad633 is used as a squarer so both inputs are always on the same voltage).
