Author Topic: MOSFET keeps failing  (Read 5477 times)
Offline timdriedgerTopic starter
« on: October 27, 2017, 10:21:35 pm »
Hi Everyone,
Looking for some advise on the attached schematic.
The MOSFET in the design keeps failing. I suspect some type of transient voltage. How could I better protect the MOSFET?
D5 is connected to an Atmega. Supply is 12VDC. The motor draws about 2A max. PWM duty cycle about 50-70%.
Thanks!
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
Re: MOSFET keeps failing
« Reply #1 on: October 27, 2017, 10:26:07 pm »
most probably overvoltage at the gate, try adding a 4v7 zener.
We Are The Watt - Resistance Is Futile!
Online wraper
  • Country: lv
« Reply #2 on: October 27, 2017, 10:34:12 pm »
Atmega cannot output more than 5V. I think that Atmega has too weak output to charge/discharge gate capacitance fast enough. So at such PWM frequency mosfet stays in linear range big portion of time, exceeds safe operation area and fails. Use proper MOSFET driver IC or make driver from discrete components.
Offline danadak
« Reply #3 on: October 27, 2017, 10:35:08 pm »
Offline suicidaleggroll
« Reply #4 on: October 27, 2017, 10:44:06 pm »
You mentioned the PWM duty cycle, but not the PWM frequency.  How fast are you trying to run this?
« Reply #5 on: October 27, 2017, 10:45:52 pm »
32KHz
Online wraper
  • Country: lv
« Reply #6 on: October 27, 2017, 10:49:23 pm »
32KHz
Atmega certainly is too weak to directly drive gate of this MOSFET at such frequency.
Offline rx8pilot
« Reply #7 on: October 27, 2017, 10:49:47 pm »
That 100k resistor is pretty slow....keeping the GET linear and hot.
The 32khz is way fast for the available drive current.
Sent from my SM-G892A using Tapatalk
Online Dave
  • Country: si
  • I like to measure things.
« Reply #8 on: October 27, 2017, 10:51:24 pm »
You're cooking them to death.
You need a proper gate driver that can switch the transistor in a respectable amount of time. A higher drive voltage would also be nice, but not crucial.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Online wraper
  • Country: lv
« Reply #9 on: October 27, 2017, 10:53:29 pm »
there is 100R , not 100k. And gate resistor is not the major part of the problem, although should be reduced IMO. But only with conjunction of using proper gate driver.
Offline rx8pilot
« Reply #10 on: October 27, 2017, 11:24:46 pm »
The 100k is the only path to discharge the gate it seems. Not sure if the PWM is able to sink current.
« Reply #11 on: October 27, 2017, 11:28:54 pm »
Here is the signal at the gate pin.
Online wraper
  • Country: lv
« Reply #12 on: October 27, 2017, 11:31:14 pm »
atmega certainly can pull the current. But resistor is good for cases when MCU output is in high impedance state. Although 100k is not enough if pull-up in MCU is enabled. But I don't remember if default state of atmegas is with or without pull-ups enabled.
« Reply #13 on: October 27, 2017, 11:32:22 pm »
I don't have the atmega pullups enabled.
Online wraper
  • Country: lv
« Reply #14 on: October 27, 2017, 11:32:38 pm »
These are not fast enough transitions.
Online wraper
  • Country: lv
« Reply #15 on: October 27, 2017, 11:38:26 pm »
I was meaning default state after reset before pins are configured.
« Reply #16 on: October 27, 2017, 11:44:29 pm »
I believe the default state is hi-Z.
Offline Ian.M
« Reply #17 on: October 27, 2017, 11:45:49 pm »
At 14V Vdd, its only got about 8nC of gate charge.  Even if the Atmega + the 100R resistor limits the average gate current during transition to around 10mA, its unlikely to be spending over 1us in the linear region, and for sub-10us pulses its good for around 70A.  It shouldn't be running hot either unless you've skimped on the copper area - worst case it should be dissipating an average of under a watt due to transition losses, and a couple of hundred mW in I2R losses during the PWM on period.
However a 2A motor could easily have a stall current of around 30A (see: Getting a handle on brushed DC motor current @ EDN, and take several ms for the current to decrease to within the MOSFET's DC SOA rating. and the 1ms curve on the SOA diagram shows its only good for 15A at 12V Vds, rising to a peak of 30A as Vds drops to 4V.   I suspect its either going to need a *MUCH* beefier MOSFET, active current limiting, or a soft start, ramping up the PWM from zero duty cycle to cure this one.
Edit: while I was typing this the O.P.'s posted a scope trace of the gate waveform that confirms its sub-1us rise and fall.  Stiffer gate drive would be nice, as there appears to be some oscillation on the rising edge, but I wouldn't call it essential.
Insert 0.01R (or a 50A rated current probe) between source and ground, and do a one-shot capture of the current waveform for the first 10 PWM cycles from stopped, with the full mechanical load on the motor.  I suspect you'll see a grossly excessive current peak.
Offline DrGeoff
    • AXT Systems
« Reply #18 on: October 27, 2017, 11:59:43 pm »
Improper Vgs clamping/driving is one of the most common causes of MOSFET destruction.
It's not usually the drive voltage that is the culprit but the inductance in the drive circuit (including pcb traces) and failure to adequately snub switching transients (Vds).
A clamping zener is a good start, like 12V or so, to clamp transients. A good low impedance drive is also required, as the energy stored in Cgs needs to be removed quickly when switching off.
Was it really supposed to do that?
« Reply #19 on: October 28, 2017, 12:05:15 am »
Images attached to show more detail on the rising/falling edges of the gate signal.
I am ramping up the PWM duty cycle when stating the motor over ~1 second.
The motor runs for about 45 seconds every 2 -3 minutes.
We've run cycle testing for weeks at a time with no thermal issues. We've also passed all the EMC immunity testing including static discharge testing.
When a customer reports an issue (motor turning continuously with now software control) I replace the MOSFET and everything is back up and running.
« Reply #20 on: October 28, 2017, 12:25:21 am »
Image of Vgs and motor current attached.
Offline rx8pilot
« Reply #21 on: October 28, 2017, 01:07:15 am »
Curious how you are measuring the motor current.
Offline Ian.M
« Reply #22 on: October 28, 2017, 01:13:12 am »
We need the scale for the current.  How many mV per Amp?
Also its the startup transient that's of interest, not the steady state current triangle wave.
A further thought - if the customer has loose connections to the motor or a brush stuck in its holder, it could be causing a startup surge outside your 1 second PWM ramp-up period, that you just aren't getting with your (presumably) well maintained test jig.
« Reply #23 on: October 28, 2017, 03:05:19 am »
Hantek current clamp. Scale is 1mA/1mV (1:1)
Offline KL27x
« Reply #24 on: October 28, 2017, 05:03:10 am »
What is D4? It's drawn in there like a zener. Google search returns a shottky.
Ahh, neermind. I see it's just snubber. Shottky. And I now realize I have never used the proper symbol for a shottky nor put a motor snubber in my schematic.
Did you check the snubber to see if it is still alive when you changed the FET?
I'll be checking back to see what went wrong. Sounds like it could be pretty interesting to know... the mysterious things that happen so fast they can't be scoped. Unless Ian is right. Then it's just boring, lol.
I don't get how transient from the motor or VDS would get all the way to the gate, though. Why we have a few folks suggesting a zener or crowbar on the gate. The ucontroller pin has an ESD diode between its pin and Vdd, already... Is there a way for the transient to occur on the GATE side of the 100R resistor? I have never blown a FET with too much gate voltage... And I have never blown a gate without also killing the micro.
« Last Edit: October 28, 2017, 05:39:41 am by KL27x »
