Author Topic: How identify JST connector type?  (Read 4177 times)
Offline bitwelderTopic starter
« on: November 16, 2014, 08:34:57 am »
Has anyone a page that helps to identify the various JST connector types?
I have a miniboard with a tiny 2-pin JST, and a cable coming from a different board with a different 2-pin JST connector (just a teeny tiny bigger), so I'd like to know what should I order to make a JST-male-x-to-JST-female-y adapter.
For the record, the cable is to provide power to a SSD.
EDIT: after some browsing on Digikey catalog I think it's about JST-PH (2.0 mm pin pitch) and JST-XH (2.5 mm pin pitch).
« Last Edit: November 16, 2014, 09:05:53 am by bitwelder »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: How identify JST connector type?
« Reply #1 on: November 16, 2014, 12:35:22 pm »
google image search can be useful for this
Day Job: Mostly LEDs
Offline Kjelt
« Reply #2 on: November 16, 2014, 12:44:41 pm »
Use a caliper between the pins on the board and than you know.
