Author Topic: Mosfet wanted  (Read 3400 times)
Offline 10101Topic starter
  • Country: pt
Mosfet wanted
« on: June 03, 2015, 12:21:20 am »
I've searched the internet already but there are so many mosfets that i can't find the right one.
So my question is, is there any logic level (5v) cheap comon mosfet that can handle atleast 1 amp when fully on in the market ? (to-92 case prefered).
PS: they will be used to make 3 h bridges controled by an atmega328p.
Thanks in advance  :-+
Offline edavid
Re: Mosfet wanted
« Reply #1 on: June 03, 2015, 01:19:21 am »
NTD3055L in IPAK?
« Last Edit: June 03, 2015, 01:23:26 am by edavid »
Offline LabSpokane
Re: Mosfet wanted
« Reply #2 on: June 03, 2015, 04:32:44 am »
NTD3055L in IPAK?
 In my searches, the 3055 seems to trickle to the top in bang for the buck.
« Last Edit: June 03, 2015, 06:15:05 am by LabSpokane »
Offline agehall
Re: Mosfet wanted
« Reply #3 on: June 03, 2015, 05:52:32 am »
If you are looking to create H-bridges, why not have a look at the BTN7971B and newer models. They might be overkill for your application but they form half H-bridges all in one piece and I'm sure there are even more suitable ones (i.e. full H-bridge ones) if you look for them. Just giving you a starting point here...
  • Country: pt
Re: Mosfet wanted
« Reply #4 on: June 03, 2015, 04:12:41 pm »
The NTD3055L seems to be a good option !!! just need to check the price with a local distribuitor  :-+
I think that an h bridge ic maybe it's a  bit overkill since i want to make it as simple as possible.
Thanks to all that tried to help  :)
Offline LabSpokane
Re: Mosfet wanted
« Reply #5 on: June 03, 2015, 05:35:52 pm »
Without a doubt it is overkill, but one generally must buy 10 ore more for a decent price, so it's nice to have a very flexible, inexpensive MOSFET on the shelf. :)
