Author Topic: Need help on a simple (so i thought) circuit  (Read 10162 times)
Offline rs20
Re: Need help on a simple (so i thought) circuit
« Reply #25 on: November 22, 2014, 11:33:07 pm »
Sooo.. Like this?
Yep, that should work nicely. (BTW, you've basically just made a NOT gate there, you could also use a CMOS NOT gate with a single pullup at the input. But who has those lying around?)
Online IanB
« Reply #26 on: November 22, 2014, 11:33:24 pm »
Offline nightfox7Topic starter
« Reply #27 on: November 23, 2014, 12:01:41 am »
Awesome, thanks guys. :)
Now, would this be the same thing with a npn?
Online IanB
« Reply #28 on: November 23, 2014, 12:19:06 am »
No, but you could try something like this:
« Last Edit: November 23, 2014, 12:22:43 am by IanB »
« Reply #29 on: November 23, 2014, 12:38:40 am »
THIS WORKS.  :clap:
thanks so much, i'll post back here when i get the final thing all soldered up, so y'all can at least see what you were helping me with :D
Offline rs20
« Reply #30 on: November 23, 2014, 12:45:05 am »
As mentioned earlier, the NPN version of this circuit consumes about 1mA all the time, while the input is floating. The PNP version consumes virtually nothing when the input is floating. Just something to keep in mind if there are batteries involved?
« Reply #31 on: November 23, 2014, 01:01:38 am »
I plan on building the PNP version as there are fewer components (smaller board, less weight), and because of the power consumption issue. :) I am just super happy to see it doing what I want, and I've learned a lot..
Offline sv2hqx
  • Country: gr
« Reply #32 on: November 26, 2014, 09:30:44 am »
I think you should put a 5 volt relay with low current or an 7805
You find them both on old routers
73
Sent from my Optimus 4X HD using Tapatalk
« Reply #33 on: December 03, 2014, 04:30:48 am »
73
I didnt know if there would be any weird kickback with a relay..
I am using a 7805 to regulate voltage.
73s
-Seth
Offline rs20
« Reply #34 on: December 03, 2014, 07:21:15 am »
73
What on earth? In what world are a 5 volt relay and a 7805 voltage regulator interchangeable alternatives?
