Author Topic: eMMC and CLK signal  (Read 948 times)
Offline JaneTopic starter
eMMC and CLK signal
« on: March 31, 2020, 04:48:36 pm »
Obe of the signals that eMMC require is CLK signal. THis signal is generated by CPU. Does anyone know the frequency ( and voltage value) of that CLK in mobile phones?
Thanks
Offline Manul
  • Country: lt
Re: eMMC and CLK signal
« Reply #1 on: April 01, 2020, 11:54:31 am »
I would say it should be 3.3v or 1.8v logic levels. In a mobile phone (if it is reasonably new) maybe 1.8v is more likely, because of power savings. Frequency can be anywhere from 10's to 100's of Mhz. More likely 100, 200. You need to measure, it is impossible to tell from what you provided.
