Author Topic: Function Generator Amplitude vs. Scope Amplitude  (Read 5655 times)
Offline pheller
« on: October 30, 2010, 06:23:41 pm »
Greetings,
  I am a beginner, with a a Rigol DS1102D and a Rigol DG1022A.
Anyways, I'm just learning the two pieces of gear, and I'm stumped by something.
I set channel 1 of the Function Generator to output a 1khz Sine Wave at 1Vpp, no offset.  I connect directly to channel one of the scope with straight bnc-bnc coax.  Channel 1 is set for 1x.  I successfully get a stable waveform on the screen, but the scope measures 2Vpp.
Am I missing something here?
Regards,
  Phil
Online Simon
  • Global Moderator
    • Simon's Electronics
Re: Function Generator Amplitude vs. Scope Amplitude
« Reply #1 on: October 30, 2010, 06:37:00 pm »
are you sure that the probe attenuation is set up right, you need to select the attenuation on the probe itself and then tell the scope what attenuation the probe has, it sounds like a case where you have 10X on the probe and the scope set to 20X (the scope has settings for 1X 5X 10X 20X 50X 100X 1000X)
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline jimmc
« Reply #2 on: October 30, 2010, 06:43:59 pm »
I'm not familiar with the Rigol kit but it sounds as if the generator is calibrated for pd.
ie It has an emf of 2v p-p and an output resistance of 50 ohm, thus it will deliver 1vp-p into a 50 ohm load and 2vp-p into an open circuit (or the 1 Megohm of the 'scope).
Connect a 50 ohm resistor across the input of the 'scope and the voltage will drop to 1v p-p.
There is probably a option to select emf rather than pd somewhere in the generators menu.
Jim
Offline Bored@Work
« Reply #3 on: October 30, 2010, 06:44:24 pm »
Yes, you are missing something. The generator displays the voltage as if put into a certain load. Typically a generator assumes 50 Ohm load and has an own source impedance of 50 Ohm. It compensates for that assumed load. If you connect a load with another impedance than 50 Ohm the generator gets its compensation wrong.
To deliver 1 Vpp into an assumed 50 Ohm load the generator has to put out 2 Vpp, because the generator's 50 Ohm impedance and the 50 Ohm load form a voltage divider 1:2. That 1:2 divider than divides the generator's 2 Vpp down to 1 Vpp, so the 50 Ohm load gets 1 Vpp. And everything is fine.
You are putting the signal into 1 MOhm. With the 1 MOhm oscilloscope impedance you have a voltage divider 1:1.00005, which is as good as 1:1 for practical purposes. But the generator still puts 2 Vpp into it, thinking it is driving a 50 Ohm load, and you get 2 Vpp.
Search in the generator menu for an option to change its output impedance. That option doesn't really change the output impedance, it remains 50 Ohm. But it changes what load impedance the generator assumes. If it knows it puts the signal into a 1 MOhm load it will assume a 1:1 divider, and just output 1 Vpp.
« Last Edit: October 30, 2010, 06:51:54 pm by BoredAtWork »
Offline pheller
« Reply #4 on: October 30, 2010, 06:55:07 pm »
D'oh.  I'm sure this is exactly right, and I should have thought about it before even posting.
There is an option for output impedance, and I'll give it a shot tomorrow sometime.
Thanks for the hint!
--phil
Offline pheller
« Reply #5 on: October 30, 2010, 09:39:00 pm »
--phil
Had a chance to take a look again today... The generator's option for output impedance is "Load", and then an impedance of 0-10k ohms, or "High Z".
High Z must set an output series impedance of 1Meg or similar, as the scope does subsequently measure the amplitude as configured on the function generator.
Thanks again for pointing me in the right direction.
--phil
Offline Feanor
« Reply #6 on: November 02, 2010, 07:55:17 am »
It annoys me that several function generators default to 50ohm impedance every time you turn them on. You then get double the voltage you expect on a high impedance like an ADC input.
Easy way to kill a chip. Wouldn't the safer option would be to default to high impedance?
