Hi all!
So I’m doing a small project that requires 360 degree movement in two axes. I’ve designed it so the motor for Y-axis (tilt) is attached to the X-axis (pan).
The problem is that the cables get all twisted...
Is there a "module" type of a thing that can couple a bipolar stepper motor cable, 4-wires and 1A per phase?
I know a thing like this must exist because it’s a common problem but I can’t seem to find any of the shelf type things...
Worst case scenario ill make it myself using pogo pins and exposed copper traces on a PCB.
I did solve a similar problem at a previous job by using two coils, one for the rotating mount and on for the static part (it was just for communication)
