Hey there, I want to make a pcb with a interboard hdmi signal due to chassis port placement. In the past ive been making a ridiculous in house interboard hdmi cable using aluminum foil tape around the tdms pairs and their ground. Which worked quite well 70% of the time. To avoid the 80 points of solder and misalignment points of failure I thought it would be nice to use A short 150mm idc cable to a male hdmi board mount like some Ribbon cable drone boards.
Ive been looking at specifications and high speed design im not sure if it the cable would need a ground plane or some spec i havnt considered or can calculate. Any advice on looking at specifications to manipulate them over non standard cabling? Ive been thinking of making a proof of concept board to test and learn how to do eye diagram compliance testing but would be nice to be confident of a design before a prototype.
As an aside ive also been looking into laying out the impedance matched tdms on a 2 layer board where most documentation implements a four layer design. Any advice on that? Its a relativly short run from the hdmi to the idc mezzanine and should be able to have a uninterrupted ground plane due to the relative simplicity of it, hdmi is a focus but will also have ethernet and usb on the other side of the board.
Thank you for any advice on this, i strive to offer my own expertise one day.
First post gotta have a emoji.
