Author Topic: Can I use this for both EEPROM's and Microcontrollers?  (Read 380 times)
Offline MidphaseTopic starter
    • KaysLABS
« on: May 04, 2024, 04:24:48 pm »
Howdy. I need to program an ATMega644p, but I also would like to be able to write to EEPROM's to update the firmware of several vintage synths that I have. I am leaning toward purchasing the XGecu T48 [TL866-3G] Programmer and I was wondering if it would work for both uses?
https://www.amazon.com/dp/B0B59959PR/?coliid=ILHR996DWG7WD&colid=6QC7U6MBJ09D&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
Sorry for the total noob question but when it comes to actually programming chips, I am completely ignorant.
Another concern that I had with the XGecu T48 is that the ATMega644p is not listed, however the ATMega644pa is listed. Judging by the data sheet that I found on Mouser, they appear to be pretty much identical from what I can tell, but is device compatibility based on the hardware or the software?
Many thanks for any info you're willing to provide!
Offline Kleinstein
Re: Can I use this for both EEPROM's and Microcontrollers?
« Reply #1 on: May 04, 2024, 04:37:42 pm »
The 2 AVR versions should be pretty much compatible, if there is a difference at all and not just the A missing in the listing.
The difference would be mainly a minor difference in the power consumption and maybe a different µC ID. So one may have to tell the programmer to accept the different ID or ignore a difference in the ID.
    • KaysLABS
« Reply #2 on: May 05, 2024, 01:37:59 am »
That's what I figured, thank you!
