If power supply says output is 20 volts and 8.5 amps. and incoming mains fuse is 4 amps and recifier bridge is 4 amps, is that okey?
I once had it blow up on me, fuse went and rectifier went. So since I had it replaced with 4 amp 600 volt rectifier and some wire for a fuse. Long long time went by, perhaps since 2017 or 2018. Yesterday I opened it up, bought the correct fuse and stuck in there 10 amp 1000 volt rectifier bridge.
