No. The lowest frequency it can display is 9 kHz. The span is the display width. So you set, say, 9 kHz center frequency and zero span, and you get a display with no span that covers from 9 kHz to 9 kHz with 9 kHz in the middle.
When setting up RIGOL DSA 815 I don't have to use "center frequency + span". I can explicitly set "start frequency" and "stop frequency" instead. These are two alternative (and equivalent) methods of specifying the display window. "Start frequency" is the left edge of display, "stop frequency" is the right edge of the display.
The manual clearly states that I can set these values as low as 0 Hz. So, what is going to happen if I set "start frequency" at 100 Hz and "stop frequency" at 1 kHz? What is this device going to display if, according to the above answers, it cannot display lower than 9 kHz? What would be the point of these settings going all the way to 0 Hz then?
The zero span mode of a spectrum analyzer...
I'm not sure why "zero span mode" is even mentioned here. My question has nothing to do with "zero span mode". When I mentioned "0 Hz" I wasn't talking about span at all.
Once again: these devices allow setting "start frequency" as low as 0 Hz and "stop frequency" as low as 100 Hz. That would be the left and the right of the display window. Why are they allowing that if, according to you, they can't analyze under 9 kHz? This is not intended to sound as an argumentative rhetorical question. I really would like to know what these devices are going to show on their screens.
