Hi All,
I have a school demonstration project in which a slowly varying bipolar sine AC voltage (~0.1 Hz) is putting current through a coil.
in order to demonstrate that a magnetic field is generated, two compasses are in close proximity and show the alternation of the polarity by constantly reversing.
In order so illustratively show that the current flow is actually reversed I would like to use a moving coil meter with a custom "scale" showing N and S in red and green. For this the resting position of the needle has to made at half scale - i hoped for the screw adjust to be able to, but after checking three different meters, i came to the conclusion that this really only sets +-10% FS or so - which is reasonable i think.
True bipolar meters (as used on some Kepco BOP models) are quite hard to find around....
The meter i would like to use is 60 mV to full scale. What would be a good strategy of offsetting the meter electronically ?
using my function gen (sine, 100mHz using 30mV offset) to test it did exactly what i want in the application...
Did anybody come across this need ? is it weird ?
Would you use an AC coupled (10uF or so) op amp and bias it accordingly to half scale ? is this over-engineered ?
Thanks in advance!
