I find it annoying how much energy gets dumped into this cheap little MP3 player to charge it's Li-ion battery. IDK how it charges (compared to other Li-I batteries), or what the circuitry is. IDK if it keeps trying after it's topped up. It just doesn't seem right for it to use so much energy that's just getting dumped into heat.
I'm imagining it's passing 5V across some diode after charging is over, rather than shutting it off.
There's no question here, I've had it apart, I should look up the MCU in it again, it's just annoying. Makes me worry it's going to fry itself, the case probably gets to 45deg C (125F iirc)
