Hey, thanks again PA4TIM!
The problem is that I am not doing this for my own use, I am building this for someone who is... well, I would like to avoid this persons use of the device in any way than just simple on-off, plug and unplug. Taking the battery out for charging, battery monitoring and such actions should and needs to be avoided by any means.
I have the amp running at home with SLA battery, but again, it needs to be portable, very portable, and easy to charge (plug and play) - not exactly SLA-s qualities. I wanted to use LiFePo4, but it is too expensive including needed protection pcb's, RC's battery pack tough to maintain and also expensive.
I have to get use of You now, when You are that kind
Please bear with me and confirm my math.
1. Let say the amp is 88% efficient at 8 Ohm load, 10W per channel capable (stereo). Assuming 12V supply. Then, it should be that it uses 1,6A if 100% efficient, which it is not, thus asking for 1,4A as a maximum needed. Correct?
2. For the sake of argument, let's say I can provide a 12V, but 1A supply to it. I now have 0,4 A missing for it to play along even at the loudest setting.
3. By testing, I concluded that the only scenario this comes to show is only at deep bass notes, which is logical.
4. Now, my possible solutions are to add a capacitor in front of the amp input, hoping it would have enough storage to fill in when lacking, which is not often, as the that deep bass is not that much present, and it leaves enough space between to allow the capacitor to get ready for another round. Am I correct by now? I was hoping that supercapacitor would be ideal, cause of fast charge/discharge ability, thus asked here for pointers. If somebody can say how big it should be to play a part here, or confirm I can just use a regular capacitor, please go ahead.
5. Next solution is to limit the output, but then I would like to solve it inside of the circuit, so I do not allow the amp to amplify to the levels that are problematic. I would not want that it is even possible to rise output to problematic levels, so I need a solution within. I do not like this solution a tiny bit
6. Other solution is to try and filter out the deepest bass notes, so the amp never tries to pull whole 1,4A. I do not like this either.
7. The last solution I can think of, is that I go with 9V and 1,5A, which is enough and possible with the exact same circuit, but then my lack of knowledge comes to the scene big time. I know this will limit the output, which is less important and I can deal with that on other fields, but how about the battery? This battery packs has some kind of a constant current boosters right? So they supply the rated output of 9V till the drain of the battery? It does not come lower than 9V?
Cause the amp will run at 9V, but it will not at 8V...
Any comment is welcomed and payed with a virtual beer. Or an apple, if You prefer virtual fruits.
