Author Topic: MSO5000 Signal generator question  (Read 465 times)
Offline adras
« on: August 10, 2019, 06:58:03 pm »
Hey,
As I want to play around with some 12V PWM fans, I need a 22khz signal to get them running. Luckily the MSO 5000 series has a 2 channel signal generator. But since a lot of things can go wrong when you're playing around with electronics I was afraid I could kill my precious Oscilloscope. The idea is simple, what if I accidentally hook up 12V+GND to the signal generator probe? Will it survive that?
Hope somebody can shed some light on this.
Offline ledtester
Re: MSO5000 Signal generator question
« Reply #1 on: August 13, 2019, 06:57:06 pm »
Some ideas:
- use an optocoupler to isolate your signal generator from your fan circuit; here's a discussion with a schematic:
https://forum.arduino.cc/index.php?topic=507639.0
- use a cheap microcontroller to generate the pwm signal
- get one of these:
https://www.aliexpress.com/item/32835541668.html
(search for "Signal Generator PWM Pulse Frequency Duty Cycle")
