Author Topic: Multi-color/ bi-color LED ( 2 cathodes and 1 anode)  (Read 2437 times)
Offline Dr_Taco_CatTopic starter
« on: August 26, 2014, 12:20:37 am »
Hello, I was wondering if there are any multi-color/ bi-color leds that have 2 cathodes and 1 anode. I am working on a project and I want to use 1 multi-color led, but the IC's pins go to ground. I am using 2 pins on the IC ( UCS1001-2-BP-TR ) that show attach detection and/or an error. All of the leds available seem to only have 1 cathode and 2 or more anodes.  Is it possible to make a single LED with 2 or more cathodes and 1 anode? (if it is possible, im trying to get through hole parts not SMD, but any info will help )
This is the kind of led i'm looking at, but this one only has a single cathode/common.
http://optoelectronics.liteon.com/upload/download/DS20-2001-645/S_110_LTL1BEKVJNN.pdf
Dr. Katz
Offline David_AVD
Re: Multi-color/ bi-color LED ( 2 cathodes and 1 anode)
« Reply #1 on: August 26, 2014, 12:41:21 am »
All of the 3-pin bi-colour LEDs I've used were common cathode.  The Digikey parametric search doesn't have a CA / CC selection which is ominous.
You can definitely get RGB LEDs in CA or CC though.  Maybe that's near enough for your needs?
Offline ludzinc
    • My Misadventures In Engineering
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #3 on: August 26, 2014, 01:01:17 am »
In addition to the above suggestions (which are good ones), what about using a dual transistor in a small SOT23 (or smaller) package to switch your CC LED with a pair of grounds from your chip?  Do you have enough board space for another SOT package?
It's not always the most popular person who gets the job done.
Offline n6plm
« Reply #4 on: November 02, 2019, 03:12:19 am »
I found this Lumex part: SML-LX15IGC-TR, red/green, common anode
Offline mariush
« Reply #5 on: November 02, 2019, 03:15:40 am »
And do you think the guy is still waiting for an answer?  He asked in 2014
