On the theme of equipment, I would suggest you at least consider the capabilities of the Digilent Analog Discovery 2. This one gadget has a 2 channel Arbitrary Waveform Generator, a two channel Oscilloscope, a dual output power supply, 16 channels of digital input/output with protocol decoding and a lot of other features.
I have the feeling that a lot of folks just blow off this recommendation. In my view for LEARNING electronics, there is nothing like it. Every tool I need in a small, breadboard friendly package. Maybe it is suboptimal for tinkering and I'll concede that when I want to see some arbitrary waveform, I might use my scope(s) but if the intent is to breadboard small circuits, there is no tool on the planet that comes close.
Read over the Features list and download the free Waveforms software. There is a "Demo" device that will allow you to exercise the various features. There are a lot of videos on YouTube and they are probably worth watching.
The problem is, it's expensive by the time you get it kitted out. Heck, it starts out expensive even when just bare bones! You can delay some of the add-ons and just use it the way it comes. Or, think about buying 2 or 3 Breadboard Adapters. You can then build up an experiment per breadboard and keep them assembled for a while. The other stuff, like the BNC adapter and scope leads can wait. BTW, you lose the differential input capability of the AD2 when you add the BNC connectors. The shell of the BNC connector will be connected to earth ground through the PC - if the PC is grounded. Be careful here! I don't tend to use my BNC adapter very often but I have other scopes. YMMV on this...
https://store.digilentinc.com/analog-discovery-2-100msps-usb-oscilloscope-logic-analyzer-and-variable-power-supply/https://store.digilentinc.com/breadboard-adapter-for-analog-discovery/Look in EveryCircuits -> Examples -> RC Step Response I like to build this circuit with a 10k resistor and a 0.1 ufd capacitor. I then hit it with a square wave (offset such that the voltage swings between 0V and, say, 1V) with about a 12 ms period. That leaves 6 ms high and 6 ms low and since the time constant Tau = R*C = 1 ms, I get 6 Tau high and 6 Tau low. We know from 1-e
-6 that we are 99.75% of fully charged/discharged in 6 * Tau. Experiment! Cut back to 3 Tau or stretch it out to 10 Tau. Exercise your calculator to figure out the percentage of full charge.
The EveryCircuits video on the home page of their web site deals with this very circuit around 2:30 In the Example they settle on 5 Tau. Fair enough but it's only 99.33% charged.
I can spend an entire morning with just these two parts and the AD2. We know from ELI the ICE man that the current leads the voltage in a capacitive circuit and that it leads by 90 degrees. Prove it! You measure current using the differential input feature of the AD2 scope across the resistor (differential connection) and voltage across the capacitor on channel 2. See attached PhaseShift.png. The yellow trace is current through the resistor (by measuring voltage across the resistor) and the blue trace is capacitor voltage. You can see that the yellow trace leads the blue trace by 90 degrees - exactly what ELI the ICE man predicts.
https://www.khanacademy.org/science/electrical-engineering/ee-circuit-analysis-topic/ee-ac-analysis/v/ee-eli-the-ice-manOr maybe you just want a Bode' Plot of the RC filter - see BodePlot.png Note how the -3dB point occurs at 1/(2*pi*R*C) - I'm telling you, this stuff is magic!
See the section Cut-off Frequency and Phase Shift here:
https://www.electronics-tutorials.ws/filter/filter_2.htmlI could go on for pages about this tool. It really is the best thing around for learning - maybe that's why so many universities have adopted it.
I could put on a fairly long class using just those 2 parts and the AD2. Wait until we get to transistors!
Alas, there is a difference between "learning electronics" and "tinkering with electronics". The AD2 is more aligned with "learning electronics". See the "Real Analog" course at Digilent.
A 27" scope screen is pretty cool!
ETA: I added the AD2 plot of the forced response example discussed above. 10k Ohm, 0.1 ufd, Tau = 1 ms
