most for repair ..making my own circuits.. and other stuff... i need this to be more accurate...
i need to measure
(A uV) dc most
pF- 2200 uF(if you find some that dosent have so much volume at farrads..ill buy a capacitor meter..no problem)
Hz at 100 hz
these are the most i need ..other measurements i dont care
(sorry for my bad english)
Lightages and
Frost made excellent recommendations IMHO.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/xsmiley.gif.pagespeed.ic.R8GFI-pF6f.png)
Staying away from mains, the Uni-T UT71B or C models would do everything you've mentioned. Or go with either of the Brymen (BM257 or BM815) units if you want something that could also tackle higher voltages safely at some point down the road as well (better input protection). BK 2709B is still in the running as well.
Check for reviews on the models listed to get a feel for their strong points and limitations (poor backlight, slow on certain functions/auto-ranging, ... sorts of things), and see which one will best fit you. Amazon, blogs/forums such as EEVBlog, and YouTube would be great places to look for these.
Hope this helps, and good luck.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/xgrin.gif.pagespeed.ic.QVVz6XIT20.png)
