Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Multimeter Diode Test on Transistors??
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Multimeter Diode Test on Transistors?? (Read 855 times)
Robbie010
Contributor
Country:
on:
February 06, 2019, 06:44:01 pm »
Evening all,
I got myself a cheap Multimeter today that has a Diode test setting. I read online that this can be used for checking transistors but when I test one it just gives me a number without telling me what it is i.e V, mV etc etc, so what exactly is this test telling me?
When testing an MPS L01 (BJT NPN) Transistor I get the following readings:
Leg 2-3 = 518
Leg 2-1 = 521
Is it forward voltage?
Thanks
Logged
mikerj
Super Contributor
Country:
Re: Multimeter Diode Test on Transistors??
Reply #1 on:
February 06, 2019, 06:53:58 pm »
That will be the forward voltage in millivolts.
Logged
Robbie010
Robbie010
Contributor
Country:
Reply #2 on:
February 06, 2019, 07:01:42 pm »
Thank you very much.
And is this number variable dependent upon the voltage in or would it remain constant (to a certain point)?
Logged
David Hess
Super Contributor
Country:
DavidH
Reply #3 on:
February 06, 2019, 08:15:24 pm »
Those numbers are the forward voltage drop of the two junctions. If your measurements are good enough, which includes not holding the transistor in your fingers while making the measurements because the forward voltage drops change by about -2mV/C, then I believe the emitter junction will have a slightly higher voltage drop than the collector junction. But the diode test is mostly useful for verifying that neither junction is open or shorted rather than revealing anything about performance.
Logged
Aubrey999
Newbie
Reply #4 on:
February 07, 2019, 09:01:52 am »
Yes, from my experience, I find that the resistance of the Emitter is usually the higher one, regardless if it is NPN or PNP.
So that is a way to work out the polarity of the transistor, and the lead-outs.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
