Author Topic: Multimeter mistake: worried about outlet  (Read 2838 times)
Offline greybondTopic starter
« on: July 25, 2018, 10:54:59 pm »
I made a mistake while attempting to use a multimeter to measure the voltage on a wall outlet that I was about to hook up an appliance to. I set the multimeter to ACV, but I put the probes into the mains. There was a spark, the wires to the multimeter blew, but the multimeter is fine and the outlet still works. I just want to make sure that there isn't anything else I should be worriesd about, except for the fact that I made a bad mistake with something I obviously shouldn't have been messing with.
Offline Simon123
  • Country: si
    • Youtube channel
Re: Multimeter mistake: worried about outlet
« Reply #1 on: July 25, 2018, 11:22:02 pm »
So you had the input leads connected to amps jack?
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #2 on: July 25, 2018, 11:30:22 pm »
Welcome to the forum.   :phew:
From what you have described it sounds like you had the leads placed in the incorrect inputs on the meter, most likely the inputs intended for current measurement instead of those for voltage.
Please provide the multimeter make, model and ideally a picture, this will save people guessing or making assumptions as to what occured and what you may now need to check in regards to the meters safe operation.
« Reply #3 on: July 26, 2018, 02:55:57 am »
This is how I had the multimeter set up before I attempted to read the voltage.
Offline james_s
« Reply #4 on: July 26, 2018, 04:15:01 am »
That looks fine, are you sure you weren't imagining the spark?
Offline SG-1
« Reply #5 on: July 26, 2018, 04:24:23 am »
Can you show us a picture of the blown leads ?
There could be damage to the blades in the outlet.
How did you test the outlet to see that it still works ?
Trip a breaker ?
« Last Edit: July 26, 2018, 04:27:39 am by SG-1 »
Advice is a dangerous gift, even from the wise to the wise.
Offline bitseeker
« Reply #6 on: July 26, 2018, 04:35:13 am »
That setup looks fine and should not result in any sparks. I've measured much higher voltages in ACV and DCV modes with no such incident, although not with the same multimeter. If the meter was configured as pictured, it should've operated just fine unless there's a defect inside.
Is it possible that the rotary switch was set one click to the right on \$\Omega\$ instead? That would be more in line with bad things happening.
Could you have had the probes crossed such that the exposed metal sections came into contact with each other?
Anything rattling around inside the meter?
« Last Edit: July 26, 2018, 04:37:37 am by bitseeker »
Offline mikerj
« Reply #7 on: July 26, 2018, 06:25:28 am »
Hmm, the mA range uses the voltage input terminal, never a good sign.  Could you maybe have accidentally selected AC mA rather than ACV?
Offline alsetalokin4017
« Reply #8 on: July 26, 2018, 06:54:44 am »
Time to open up the meter and give it a thorough internal examination.
I wouldn't trust it to be safe, or accurate, until the reason for this event is found and corrected.
« Reply #9 on: July 27, 2018, 04:27:28 am »
I threw away the leads, but they were blown out mostly by the probes and somewhat further along the cord. The outlet still works and the breaker didn't flip when it blew.
« Reply #10 on: July 27, 2018, 04:32:22 am »
Also I definitely didn't imagine the sparks... my hands were burnt.
(Sorry I'm doing a bad job of replying and quoting text... New here)
I'm sure that is the way I had the multimeter set up when I tested it. I'll take a look at it tomorrow and see if there's anything rattling in it... Not planning on using it again any time soon until I figure out what happened.
« Last Edit: July 27, 2018, 04:34:19 am by greybond »
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #11 on: July 27, 2018, 05:00:45 am »
Time to pull that sucker open and take some photos of the insides to see what went pop.
If you are lucky it's just a fuse, if you weren't so lucky it'll mean some interesting photos. :D
Offline SG-1
« Reply #12 on: July 27, 2018, 12:45:55 pm »
If the metal ends were damaged, then similar damage occurred inside the outlet.  :scared:
I always use a CAT IV instrument to probe my mains.  If you are checking an outlet, the next thing you know, there you are inside the panel.
