I have a medium sized AC transformer sitting down and doing nothing. It is a mains step-down transformer, with a center-tap at the secondary side giving two options at 30/15VAC. Each side measures around 11 centimeters, and the thing weights 4~4,5 kilos. The only spec I can verify for sure, is that it used to work inside a 1000Watt UPS, along with two 12V batteries. (By the way, why 2 of them?)
So, I had the idea (maybe stupid), to rectify to DC both 15VAC outputs and make an emergency booster for my bike's electric starter, connected in parallel with the small 12Ah Varta AGM battery, which by the way always struggled to crank the engine.
The bad thing is that the engine is a twin cylinder with a lot of compression.
The good thing is that the mains in my place is 230V.
The engine is fuel injected, and fires up really fast. This is good as well.
I can't remember the battery's CCA's (Cold Cranking Amps). Magnitude of 100A perhaps? I never managed to buy a set of proper inductive clamps for my multimeter.
So, do you guys think this is feasible at all?
Note that the battery will always be in place, meaning that the transformer will never take 100% of the load.
And if it is feasible, what is the safest and most efficient way to rectify such a big amount of current? Monster diodes? Thyristors? Do I have to worry for the pulsed output? Much smaller brushed dc motors seemed to work with no problem.
Thanks!
