Guessing a bit, but what comes to mind is that you could wrap a primary side using something like 40 turns, using a steel or ferrite rod.
Then, a magnetically coupled secondary wrapped on top, after some insulating sheet goes around primary. I think you are asking about putting a third winding that would be simply wound, again, but not electrically connected, to either of the other windings...(?)
