Are you expecting the output voltage to be adjustable? For instance you would generally not want to drive a MOSFET gate with more than 15 volts on a 24 volt supply.
No, just to work with whatever the supply voltage may be. Good point about gate voltage, that had slipped my mind. Given that it seems common for many MOSFETs to have a V
gs(max) of 20V, if I want this to work up to 24V, I would need to factor in some gate voltage clamping on a discrete solution.
Do you want the output to also support a high impedance state like a three-state driver?
At this moment, I'm not sure. How will it affect things if I do?
What kind of transition times were you expecting to support PWM operation? The transition time question is important because linear operation becomes difficult at high speeds and more complex output structures must be used. 1 microsecond is feasible in a linear design and 100 nanoseconds in a lower current linear design but faster may require an open loop output which is more complex and less intuitive.
Are you talking about edge rates? Or PWM frequency? For the latter, I'm not envisaging anything too strenuous - from 10's of Hz up to only 10's of KHz. For the former, I'm not sure whether a slow transition time will have any bearing on my intended application. What I'm aiming to do with PWM output is twofold: a) do things like variable duty-cycle speed control for a motor or reduced hold current for a relay/solenoid; and, b) simulate a square-wave frequency-output sensor, to be used as an input to some other system. With the latter, I would imagine so long as the transition time is not so slow as to glitch/flap the receiving input, anything's okay, and for the former I assume a faster transition time is better for MOSFET power dissipation, but has little other benefit.
Drivers like the classic TLE5206 and TLE5205 (if you want a fun task, work out the difference from the datasheets between those parts! It's subtle but important.....)
Umm... the TLE5205 can put the outputs in to a Hi-Z state, and the TLE5206 can't?
Speaking of Infineon, I have been looking at the
TLE4207G, which looks great but appears to be discontinued at all the major distributors, even though Infineon on their website say it's an active part. Anything similar out there?
Edit: Also TLE6208-3G, which is NRND, although I have also found the ON Semi NCV7703, which seems to be a part of identical function (possibly a second-source for some OEM, I suspect), and thankfully is fully 'active' (at least, the 'C' revision).
