Author Topic: Why does my switching regulator circuit deliver 4.4V instead of 1.2V?  (Read 672 times)
Offline soFPGTopic starter
Hello,
it seems like I am not even capable of building a correct switching regulator circuit. My idea was that this circuit should produce 1.2V from 5V input (see attachment).
However, what I am getting is 4.4V.
Any idea why this could be (datasheet of JW5033S: https://datasheet.lcsc.com/szlcsc/1906281506_JoulWatt-Tech-JW5033S_C324577.pdf )?
« Last Edit: May 29, 2021, 08:03:01 pm by soFPG »
Offline AndyC_772
What are the pin numbers, and which package are you using? The two options are different.
Ye, you have the finger right on the spot.
My footprint is wrong  |O :-[ :-X :-\ :palm:
Offline Monkeh
Quick fix: Put the chip on upside down.
I don't think this will do it. I switched BST and FB
Offline Monkeh
Ah, well, if you didn't flat out use the wrong pinout in its entirety, no, that won't work.
Offline AndyC_772
Pro tip: Always include pin numbers on every schematic symbol, unless it's just for a 2 pin passive.
Also, not that it applies in this particular case, but always make every pin on a device visible, especially any exposed pads on QFN and similar packages.
The following users thanked this post: soFPG
