Author Topic: SG3525 Oscilator current  (Read 457 times)
Offline aless2056Topic starter
  • Country: br
« on: May 30, 2021, 03:21:59 pm »
Guys, just to be sure, since I'm not very familiar with the datasheet.
Is the SG3525's oscillator current 5ma? Esyou thinking of using an AD5220 as RT, the maximum current of the variable resistance is 20mA?
Online T3sl4co1l
    • Seven Transistor Labs
Re: SG3525 Oscilator current
« Reply #1 on: May 30, 2021, 03:47:27 pm »
Even easier, just use a variable current sink.  It doesn't need to be a resistor.
Seven Transistor Labs, LLC
  • Country: br
« Reply #2 on: May 30, 2021, 04:27:47 pm »
I will use the AD5220 with RT and the CT will be a fixed value capacitor. I will use the AD5220 to vary the frequency of the PWM
