Author Topic: Multiple Questions On Oscillators And Amplifiers.  (Read 766 times)
Offline XMATopic starter
« on: March 31, 2018, 10:52:41 pm »
Hello, I am getting into oscillators and amplifiers, and I see that circuits and some amplifiers require a +9v and -9v and a ground. so could someone show me a simple schematic of how would I got around making it, or at least explain to me? I saw a pic showing that if you got two batteries and put them in series, the top is +v and the bottom is -v and the middle would be the ground. but im aiming towards using a single 9v battery.
also on amplifiers im wondering what kind of amplifiers are there, especially audio amplifiers. I know there's op-amps based and there are transistor-based amplifiers, what more are there.
also with oscillators from transistors and op-amps, how does it make it oscillate. arent the op-amps and transistors only able to gain current.
now on something I don't ever seem to understand is, how the hell does a transistor go around amping the current/voltage. also with that when I take a look at circuit diagrams they always have a resistor, or two, and with that, I don't understand why would u need a resistor for a transistor to amplify. doesn't the resistor drop the voltage/current?
very sorry, noob.
« Last Edit: March 31, 2018, 10:57:51 pm by XMA »
Offline Cliff Matthews
    • General Repair and Support
Re: Multiple Questions On Oscillators And Amplifiers.
« Reply #1 on: March 31, 2018, 11:04:03 pm »
Hello and welcome. I would suggest you read through a while on DC and AC circuit fundamentals. We have a help area here:
*https://www.eevblog.com/forum/beginners/electronics-primers-course-material-and-books/
https://en.wikipedia.org/wiki/Electronic_oscillator
« Last Edit: March 31, 2018, 11:06:22 pm by Cliff Matthews »
Online rstofer
« Reply #2 on: April 01, 2018, 01:54:31 am »
Google for 'single supply op amp circuits'.
Sure, you can use a single supply but you have to bias your AC signal up to Vcc/2 in order to get the output to swing between gnd and the positive rail.
https://www.ti.com/lit/an/sloa030a/sloa030a.pdf
There are lots of videos on this topic.
