Author Topic: Fixing Calculator LCD missing pixels  (Read 1020 times)
Offline sairfan1Topic starter
« on: January 24, 2022, 02:14:04 am »
Please refer to below image this calculator LCD is missing pixels, when i press this ribbon cable it shows correct digits.  A quick google shows some people fixed it by applying hot air and some with soldering iron.
I want to know what is better option, hot air gun or soldering iron? (i have both tools) I also want to know what temperature should be applied in any case.
On some posts i saw that wide face metal is most helpful, any thoughts?
Offline mathsquid
  • I like math.
Re: Fixing Calculator LCD missing pixels
« Reply #1 on: January 24, 2022, 04:07:10 am »
I’d use hot air and a pencil eraser. Heat the ribbon cable a bit, then take the eraser and press down on the cable and rub the eraser along the direction of the wires. I’ve managed to fix a few LCD issues by doing this.
I wouldn’t use a soldering iron. I’d be afraid I’d melt the cable.
Offline james_s
« Reply #2 on: January 24, 2022, 04:35:15 am »
Put a piece of paper over the ribbon and rub a soldering iron across that where the joint is. I've fixed the same problem on several Gameboy handheld games that way.
Offline rpiloverbd
  • Country: bd
« Reply #3 on: January 24, 2022, 12:27:04 pm »
I think a hot air gun is better. But, sorry. I can't recommend any temperature without knowing the model number of the LCD and seeing its datasheet.
Offline PKTKS
  • Country: br
« Reply #4 on: January 24, 2022, 01:04:32 pm »
I use a proper TIP for that...
Mileage will vary but the proper the tool greater the chance..
Paul
« Reply #5 on: January 24, 2022, 03:52:16 pm »
Any good idea temperature to set on Hot air or soldering iron while using any technics.
Offline PKTKS
  • Country: br
« Reply #6 on: January 24, 2022, 04:15:44 pm »
Both bad idea...  in less than a second a wrong setting will melt the plastics
Paul
Offline james_s
« Reply #7 on: January 27, 2022, 12:09:26 am »
The problem with hot air is it just heats everything up but doesn't press the contacts together. You need to apply both heat and pressure to the adhesive to re-bond it.
