Author Topic: Fluke 115 showes 0 Amp all the time!  (Read 4362 times)
Offline ECE MishoTopic starter
« on: November 16, 2014, 09:10:12 pm »
hello,
as stated in the title, i have fluke 115 and it can't measures amperes ( showes 0.000) always.  :palm:
is it need fuse replacement? or something else?
(i removed the fuse and the same happening)
thanks in advance~
Offline AG6QR
    • AG6QR Blog
Re: Fluke 115 showes 0 Amp all the time!
« Reply #1 on: November 16, 2014, 09:32:43 pm »
Most likely cause is a blown fuse.
To check, put your meter on ohms measurement, and using only ONE probe plugged in to the red V socket, stick the end of the probe into the A socket.  You should get a very low reading, much less than an ohm.  If the fuse is blown, you will get an infinite reading, the same whether your probe tip is touching the A socket or not.
An alternative is to remove the fuse and use both the black and red probes to check it for continuity in the normal way.  Again, you'll get a very low reading if it's good, infinite resistance if it's blown.
« Reply #2 on: November 16, 2014, 10:11:08 pm »
thanks  ^-^
the fuse (for sure!) is blown
Offline retiredcaps
« Reply #3 on: November 16, 2014, 10:16:19 pm »
Also documented in your Fluke 115 manual at (page 16)
http://media.fluke.com/documents/114_____umeng0100.pdf
Offline ivan747
« Reply #4 on: November 17, 2014, 11:57:02 pm »
Remember to get a genuine fluke fuse, not from eBay, preferably from Fluke or an authorized distributor or somewhere like Digi-Key.
