Author Topic: Mustool vs Hantek scopes. Which and why.  (Read 3825 times)
Offline aries1470Topic starter
« on: October 24, 2019, 01:16:10 am »
Hi guys,
I wanted to ask, which of these two would be a better entry level ‘scope, mainly used for audio circuits, and digital too, mainly for SPI / i2c and general duties, nothing to advanced.
These are the two candidates:
MUSTOOL MDS2112P Ultra-thin Dual Channel Digital Storage Oscilloscope With 100MHz Bandwidth 1GS/s Sampling Rate 7 inch TFT Color Screen Automatic Waveform Measurement
Hantek DSO5072P Digital Storage Oscilloscope 70MHz 2Channels 1GSa/s 7inch TFT LCD
Both have a similar price, but one is “100”MHz, while the other is “70” MHz.
Not sure how the sampling is done.
Thanks in advance for any insights.
Re: Mustool vs Hantek scopes. Which and why.
« Reply #1 on: October 24, 2019, 01:27:26 am »
Neither as their memory depths for a modern DSO can only be described as pitiful !
To be able to capture a waveform and then examine it in detail is the great strength of a DSO so don't sell yourself short here. Get something with 1 Mpts +.
« Last Edit: October 26, 2019, 07:41:49 am by tautech »
The following users thanked this post: aries1470
« Reply #2 on: October 24, 2019, 01:36:30 am »
Thank you :-)
Do you have any suggestions in that price range that these two are in?
« Reply #3 on: October 24, 2019, 02:56:32 am »
Thank you :-)
Well the issue you have is data protocol analysis on that budget.
Cheap DSO's only have so many features which make it difficult to cover a good range of usage types.
I no longer stock the very basic DSO's as their feature set is somewhat limited so I have no hesitation of recommending SDS1202X-E as a very capable 2ch entry level scope.
Here's your local suppliers listing:
https://www.triotest.com.au/store/siglent-oscilloscopes/1248-siglent-sds1202x-e-digital-oscilloscope-200mhz-2-channel-1gss-with-serial-decode.html
Offline ebclr
« Reply #4 on: October 24, 2019, 06:08:48 pm »
Wana good performance/price look for Rigol or Siglent, Both are the chineses ones with at least some engineering Inside
Special attention to DS1054 and MSO5074   both  are the best ones on their price range ( 350 USD and 999), I have both and I'm happy, avoid craps like Owon, and Hantek, is all 2nd class products
Of course, the tektronics and Keisyghts, are a little better specially on firmware, but never justify to be 6 to 8 times more expensive for the similar ones From Rigol or Siglent
Offline KL27x
« Reply #5 on: October 25, 2019, 02:14:47 am »
You can use a less expensive logic analyzer for doing the SPI/I2C stuff. You would only require the scope to verify the bus you built has clean enough signal with no funny business.
Scope has been very useful to me on occasion, and I could probably do just fine with either of those. I've never heard of Mustool. So I'd go with the Hantek.
