Hey all,
I'm a Physics/Math undergrad soon to be Computer Engineering/EE major at an engineering school (5-6 year joint degree program). My main research and interest is in Quantum Computation, and I plan to purse a EECS PhD as well as possible a Physics PhD. In my spare time, I have a lot of hobbies, some of which include electronics and mentoring a high school robotics team.
When I bought my first personal electronics gear, I was smart enough to dish out for a good Weller soldering station. However, I was stingy with the meter and couldn't afford much so I got a cheapo "MASTECH" DMM. I guess that actually turned out to be a good thing because if gave me a good excuse to get a good meter now. The other day at my robotics team I saw they were working with a similar DMM to mine (same casing). I had just finished teaching some kids how to solder so I was going to show them how to use a DMM. I grab the DMM and go to measure the voltage on our 12v battery......~0.02V unstable.....same thing same thing...I was embarrassed at first because I said "watch this" and then nothing worked lol. I get the instructor...same thing........then it jumps to 12.75V all of a sudden. Needless to say the DMM was garbage and the instructor wasn't too happy either. They had grabbed the meter from a Physics lab.
So I took the opportunity to explain the difference in quality and price between cheapo's and a good meter like a Fluke. Fortunately, my advisor in Physics at my uni was a EE so he loaded ALL the labs (including freshman) with Flukes. The circuits lab has a dozen 187's. As I discussed this with them I started to worry about my meter too. Especially since I had even used it for some quick reference stuff when working for a defense contractor over the summer. So as we continue to talk about things, I decide that it's time for me to get a decent meter.
I managed to find some school book/supplies/scholarship money to use for it so I was ready to jump at the grand poobah of Flukes and snag a 289. However, it was a bit out of my price range. After watching Dave's review, I realized that it would have been a stupid choice anyway since it is much bulkier than an 87V, takes time to "boot up", makes you dig in menus to do things, etc. I carry my meter in my school messenger bag so bulkiness makes a difference. Also, for the general purpose stuff I need it for the 289 seemed like it would be more of a disadvantage than advantage. However, I still wanted a top of the line Fluke so I decided on the 87V. The price was inline with that of a textbook, the size isn't awful, its fast, probably more rugged, and it has the added plus of being such an iconic meter that it sort of seemed like a right of passage into the Fluke world and a great first Fluke. Not to mention it had the main features I wanted (temp probe, relative, max min avg, etc.).
I am very happy with my 87V. Though I'm a little surprised they killed the 187 line since it seems like there is a gap between the 87 and the oversized 289 firmware updatable computer. That said, I think it was good that I had to get a 87V because of the history and iconic status.
The only thing that I'm a little annoyed about is that there a few things that neither the included "manual" and the real full online manual cover in descriptive detail. So I hoped to make this thread (in addition to my introduction) a potpourri of 87V related questions I and perhaps other beginners have, as well as a place for the veterans to give there tips and tricks.
Firstly, the manual shows that the display has support for both "display hold" and "auto hold" but I can only figure out how to enter auto hold. Granted, I think auto hold will probably completely replace the functionality I would get from regular hold and add some, I just wish I knew whether or not the regular one was available. I took an educated guess which turned out to be right that the regular hold lcd icon and functionality is triggered when pressing AutoHOLD in min max avg mode in the current measurement submode. Is this the only place you can access non-auto hold?
Next, I'm a little confused about the difference between using the frequency feature while in DC vs AC. The full manual gave some situations when you would use which, but it isn't super clear what the real difference is, and it's a bit confusing that there is a frequency measurement in the DC mode.
I've always been a little irked that DMM's only give you rms for AC. Granted rms is the most useful, but peak voltages can be useful and some cheap meters actually calculate rms by taking peak/?2 so clearly a peak measurement isn't a hard thing to implement along side rms. On this note, I had an idea. I figured that I could use my 87V to measure the peak voltage of an AC signal by measuring it in DC volts min max avg mode using the faster 250 microsecond time scale. I was under the impression that min max avg just did the corresponding measurement once every 100ms or 250µs and then extracted the data and DC would take literal voltage measurements. So with the faster time scale, the closer the signal was to 4kHz, the longer you would have to wait before you got a good peak sample due to a beat note type analysis. I was most interested in the peak voltage so I could calculate the crest factor of signals which would be a rough way of estimating the wave shape without a scope (sharp vs flat top vs sine). Along with the frequency and duty cycle features this would make a potent combo in a handheld meter.
So I try it out on a wall socket. I get ~118-119 rms and a max of about 162 (the min was negative and a little smaller magnitude). This was pretty close, but not quite the ?2 factor I expected. So either the signal isn't quite a sine or this idea isn't working as a peak measurement. At 60Hz it definitely shouldn't be a sampling issue. I don't have a scope but I tried using the function generator and scope in circuits lab after class and it seemed like I was seeing the same slight undershooting of my attempted peak measurement. Though I can't tell for sure since scopes don't give super accurate voltage measurements anyway. I did some reading...and I ran into some information that suggested that the PEAK min max was actually meant for just this, measuring PEAKS (duh!). I had thought peak was just a new word for fast, as in peak acquisition speed. To test this, I tried the same thing but using min max avg in AC mode. Sure enough, regular min max avg gave the rms min max avg, but when I went into peak mode it jumped up to ~162. Again this is confusing since I would expect the AC peak min max avg mode to just do faster data on the rms value, though maybe the term rms doesn't make sense at those timescales (granted I don't see how it would make sense at 100ms then either).
So what exactly is peak min max avg and how does it differ between DC and AC?
On a similar note, I'm also a little confused as to what the DC and AC measurements actually measure. At first I had assumed AC measured the true rms of the signal and DC literally measured voltage, so an AC signal would read quickly varying in DC mode and I could use the avg feature to get the DC offset. After reading some, it appears that the AC feature measures the true rms of the AC component only (no offset). They say you can get a true total rms by taking the AC and DC measurements and doing the orthogonal square square root sum up, but this leads me to believe then that the DC function actually measure the DC offset of the signal. So if you measure an AC signal using the DC mode does it actually give you the time average of the signal? In the manual they say to use a range at or higher than the AC rms measured value, but they say nothing more. If anyone would like to elaborate on this I would appreciate it.
Also, I couldn't find much on the smoothing feature. I assume it smooths the signals in some way, like a watered down version of the low pass filter function, but it's functionality isn't entirely clear to me.
Since I'm going to have this meter on me pretty often, I'd like to know all the ins and outs of it and how to use it to its greatest capacity. Unfortunately, I feel like the manual has lead me to ask more questions than it answered. I know this is a doozy of a post and I appreciate anyone who took the time to read any of it. I'd love to hear thoughts regarding any aspect of my questions or any general tips and tricks of 87V use.
Thanks!
