is widening the line until the seconde capacitor enough ?
Current must follow closed loops. If it goes out the positive terminal of a power supply (battery, voltage regulator, whatever) then the same amount of current must go in the negative terminal.
I've highlighted the current loop in magenta. (Sorry it's hard to see. I am using a simple tool to edit your drawing.)
The current starts from pin 2 of the 5mm connector 24V_FROM_POWER_SUPPLY (or BUCK_CONV_IN), travels through Q1, L1, and out pin 1 on the SOLDERING_IRON_CONNECTOR.
The same current then comes back in through pin 2 of the SOLDERING_IRON_CONNECTOR, through the current sense resistor R9, then returns to pin 1 of 24V_FROM_POWER_SUPPLY
through ground. The traces along all of those paths must be able to handle the full current, not just the +24V node between the power supply and Q1.
Study the edited schematic until you see the current loop.
