I need capacitors. I don't know what values, but I'm sure I'll need caps.
0.1uF, one per each IC, next to the Vcc pin.
Also, if you've got, say, a quad OR chip but you're only using one gate, maybe consider using one of those SOT-25 TinyLogic single-gate chips or similar.
