the results are in.... lead free sucks!
i didn't even try to solder any surface mount stuff with the pb free as i had pretty miserable results with my preliminary attempts with various awg wires. my results with kester's k100ld looked nothing like their example photos and took quite a bit of effort to produce joints i was reasonably satisfied with. ROHS is hippie idealism bull$h!t imo! good luck finding any of today's electronics
still functioning 30 years from now.
anywho... heres some pics of my latest attempts! the first picture is
Sn62Pb36Ag02 from Radio Shack, which imo, is pretty good stuff! 1oz of .015" is around $6 and lasts a good while if you aren't doing heavy utility type stuff. kester Sn62Pb36Ag02 is relatively difficult to find, especially in quantities less than 1lb.
the other two chips were soldered with Sn63Pb37 from
curious inventor. $2.50 per 1oz roll. i really like this solder! the flux seems to be a little more activated than the silver bearing, but could have been due to the thickness of the solder.
all three were soldered with a weller wesd51 equipped with the stock 1/16 screwdriver tip. temp was set 650°F. the larger max4550 was soldered with the help of amtech rma-233-uv (nasty fumes. difficult to clean. great wetting though!) the smaller max7456 was aided by kester 2331-zx water soluble. the 2331-zx seems to leave behind a powdery residue after cleaning with alcohol. this sometimes takes a lot of scrubbing to remove!
not sure why the solder mask is different on the two 28 pin boards.... didn't seem to make much of a difference soldering. i didn't even notice until i started taking the pictures.
cheers!
-sj
